Hi guys!
I need an advice from someone who's got experience of building low dome woodfired pizza oven on a trailer.
I've been reading a lot about how to do it, never made one before.
I already started to build; I was going for a full brick oven at the beginning, but then I changed my mind and this what I came up with........instead of building the dome with bricks, I can use a steel fire pit (see attachment) upside down on the top of the soldiers bricks, supported with some brackets bolted on the base.
The reason why I choose to go this way is that I realised that it needs to be built perfect to be strong enough to be transported on a trailer, excuse the to be!!!
And I know is not gonna be as my first.
I attached some pictures, not every detail is in there, here are some more:
Internal diameter:100cm
Dome height:36cm
Opening, door: 44x22cm
Flu: straight out of opening 200mm, insulated, 1200mm height with damper
On top of firepit I am thinking to pour some clay for the thermal mass that the dome (fire pit) doesn't have
Bottom insulation: Vermicrete 5 cm + ceramic fibre board 5cm
Insulation around it: aluminum foil and ceramic fibre blanket 50mm x2 held by chicken mesh
I would really like to get some advice cheeers
Giaco
Dome height:36cm
Giaco
