Hi I’m Paul from coastal town of Blackpool. Gathering information before I begin my first attempt and building a WFO. Love pizzas and baking bread. Begun gathering materials so far I have exercise ball 125kg of castable fire mortar50Kg of kiln dried sand 100 litters of perlite. And a chimney but so far the weather is too wet to do an outside build. I’m going to repurpose a old bbq as the base
There are a number of well documented cast builds in the Other Ovens Section that should answer your questions. A 100mm diameter flue is inadequate for any oven. Obviously the larger the internal oven diameter, the larger the flue diameter..A 5” (125 mm) is ok for ovens up to 28” and ovens over 42” need an 8” (200 mm) flueLast edited by david s; 03-01-2024, 12:09 PM.Kindled with zeal and fired with passion.
- Likes 1
