Hello From Ontario
  • Antonio D.
    • Jun 2008
    • 21
    Hello From Ontario
    Hello all
    Started a 36 inch low vault oven last month. The oven is now complete and ready for insulation. Trying to get some ideas on gable house.
    Tony
  • asudavew
    • Jul 2007
    • 1880
    Re: Hello From Ontario
    Welcome aboard.
    Some pics would be great!!
    Dave
    My thread:
    My costs:
    My pics:
    • Les
      • Sep 2005
      • 2945
      Yea - What Dave said. We're all about visuals
      In regard to gable enclosures, there is a butt load of those. Do a search of Ken - first one that came to mind.
      Les...
      • Antonio D.
        • Jun 2008
        • 21
        Thanks Dave ,Les
        My pictures are now up loaded, but I'm struggling on adding the link to my reply.
        PhotoPlog - Uploads Posted By Antonio D.
          Once you have the pictures uploaded in the photoplog, you can copy the [img]
          line below the picture, and place the picture directly in your reply:
          Like that.
          • sarah h
            • Sep 2007
            • 567
            From one Ontarian to another - welcome!
            There are no end of finishing styles and every oven seems to turn out unique so I'll look forward to seeing what you decide on.
            Sarah
            • dbhansen
              • Jun 2007
              • 566
              Antonio, did you embed a vermiculite layer into your concrete hearth, or is that just rough concrete I see in your picture? Looks nice either way.
              Picasa web album
              Oven-building thread
              • Antonio D.
                • Jun 2008
                • 21
                Yes I did embed the vermiculite layer. The hearth is 5" steel reinforced concrete, and 5" vermiculite.
                PhotoPlog - Hearth and Stand
                • Antonio D.
                  • Jun 2008
                  • 21
                  finally completed my oven.
                  Just need to make a door
                  http://www.fornobravo.com/forum/phot...1_IMG_0674.JPG
                  http://www.fornobravo.com/forum/phot...1_IMG_0678.JPG
                  • Pat B.
                    • Oct 2009
                    • 6
                    My first post here! I'm glad to see there are others from Ontario here. I'll be building my own WFO when spring is here... this site will be an invaluable tool to help me accomplish that. I'm just starting to find my way around and I am especially interested in seeing what other northerners have done to build a secure foundation. I'm sure I will find the info I need but feel free to point me in the right directions if you have nothing to do.
                    • Antonio D.
                      • Jun 2008
                      • 21
                      Welcome Pat,
                      I had a pool dug out the year before we built the oven. I had a 5 foot deep hole dug and we dumped all the leftover concrete in with rebar. so it's pretty solid. It is a bit of an overkill but at the time it was cheap and easy.
                      I would suggest going with a footing below the frostline (about 4 feet).
                      block up to hearth level and fill block with concrete. Styrofoam insulate on both sides of the block that is below ground level. When you pour the concrete
                      pad put a sheet of styrofoam between the concrete and the ground. Build your hearth and oven according to the plans.
                      • ThisOldGarageNJ
                        • 1436
                        welcome pat and antonio,,,
                        glad to have you guys here,,, enjoy the site, when you finish the building there is plenty of info here on cooking too
                        Enjoy
                        Mark
                        • Pat B.
                          • Oct 2009
                          • 6
                          Thanks guys!
                          Antonio, do you think I should go thicker than 6 inches on the footing?
                            If I may be so bold, I'd suggest the Canadian method of shallow frost protected foundations, If you want more that the slab-on-crushed-rock method.
                            ESB: Frost-Protected Shallow Foundations
                            • Antonio D.
                              • Jun 2008
                              • 21
                              Hi Pat,
                              6" is more than enough for a footing.
                              Where about in Ontario are you?
                              Tony
