I have a 4" hearth slab and need to choise an insulation material
will the vermiculite and concrete mix hold the weight of a pizza oven for all years that the oven will last, wont the cement fall apart from all the heat
What about using a castable insulating concrete like castilite 22 or delta crete 25 under the oven floor
can i insulate under just the floor and not under the first chain of bricks so that the weight of the oven is on the concrete and just the floor sits on the insulation
