new guy on the block
  • jimmyjam
    • Oct 2008
    • 5
    Hey from Nor Cal. I am really fired up to build a WFO- I have a old concrete slab for a foundation from the 50's. flat,smooth- will this be ok to use?
    I feel the round dome is the way to go- any suggestions on getting started?
    jimmyjam
  • dusty
    • Oct 2007
    • 575
    Re: new guy on the block
    Welcome fellow Nor Cal-er!
    Regarding the foundation:
    Sounds perfect to me. Remember that the oven hearth, slab and oven itself are very heavy. Most foundations are reinforced with rebar. If this slab was built to support a heavy fountain, and has remained sound since the 50's, it should work fine.
    I think we would all here recomend the round dome oven shape.
    I started by down-loading the Forno Bravo oven plans. These will answer 95% of your questions. Probably help you with the foundation too.
    I am sure someone here can help with the other 5%.
    dusty
    • staestc
      • Oct 2008
      • 256
      Hi jj, and welcome to the forum. Best advice is to start studying the forum, right after you download and read the FornoBravo plans as Dusty suggested. Just following though some of the thread here and watching how people build their ovens does wonders.
      Here's a link to where to get the plans if you have not allready. They are free, require you to register (different registration that the forum), but don't require a credit card or anything. Brick Oven Plans | Build an Italian Brick Oven
      Good luck,
      Travis
      TravisNTexas
      • jimmyjam
        • Oct 2008
        • 5
        Dusty & Travis-
        Thanks for the advice- I was pretty sure the cement patio was strong enoungh.
        I down loaded the plans and doing my DD.
        Where is the best place to order all the Bricks and materails? from FB? Where is FB located in CA?
        Do most Forum guys use the brick dome or buy the pre-cast...seems like a guy can save some serious $$$ going with Brick.
        I hope these ?'s are ok..
        JimmyJam
        • Les
          • Sep 2005
          • 2945
          Jimmy - you're in luck. H.C. Muddox is located in Sacramento. A member of this forum (acoma) went to their yard and got a pretty good deal on seconds.
          Les...
          • jimmyjam
            • Oct 2008
            • 5
            Les,
            Thanks, went to the site and will be going to Sac Town soon. JJ
            • Frances
              • Aug 2007
              • 2186
              It depends on what a guy (or girl) likes doing - well, that and how much money they want to spend. If you think you'll enjoy the challenge of building your own dome from scratch, do it! Its really great fun!
              But there are plenty of people here who've got precast ovens, too - you'll get to cook pizza a lot sooner that way.
              • JConk007
                • Nov 2008
                • 9
                Hi,
                The slab may be fine but you may want to dig around the outside and see if there are any footings (thicker and deeper than slab) or drill a small hole to determine the thickness of the slab. Chances are it will be fine, you dont have the frost issue? as I do in NJ were my footings are 3 ft below grade the block work is built up from there.
                If you are really Fired up and want to make pizza sooner than later go with the dome casa models. A bit more $$ overall but go together so much easier and quicker than the brick/barrel build and provide great results. I have heard as little as 2-3 wks from delivery to first pies.
                pizzamaking.com has some great info on building as well. Good luck with whatever you choose. The sooner the better.
                John
                • staestc
                  • Oct 2008
                  • 256
                  This thread popped back up, and I saw that I had missed the slab question. A slab from the 50's with no cracks that is still level? I would say go for it, but just for the record, do you know how thick it is? If not, did a bit by one side, and you will either find out how thick it is, or find out that it has footings. But I would guess you are probably good to go.
                  Travis
                  TravisNTexas
                  • dusty
                    • Oct 2007
                    • 575
                    Les,
                    Great place to buy firebricks. They generally don't sell to the public, but will sell you "seconds" for 30 cents each. The seconds are very, very adaquate.
                    I have been there many times. Let me know if I can help.
                    dusty
                    • jimmyjam
                      • Oct 2008
                      • 5
                      Dusty,
                      Thanks for the info..Did you build yours with brick or Pre-Cast? JJ
                      • jimmyjam
                        • Oct 2008
                        • 5
                        Travis
                        It is around a foot thick with a couple of cracks-nothing to big.
                        Question-
                        as far as the cement goes with cinder block- is it true to fill every other holes with cement and rebar? so, no cement between the blocks?
                        • RTflorida
                          • Jan 2007
                          • 1446
                          For the inexperienced mason, dry stacking is the way to go on this project as long as you do as mentioned - at least fill every other core and use rebar. Getting your mortar lines even and keeping the blocks level and true can be tricky, so the dry stack method has been recommended on this forum. As far as stability, I've heard of no one that has had any issues (including myself) as long as you are starting with a good slab or foundation. The overall weight when you are done will not allow anything short of an earthquake to move your stand.
                          The other great benefit - you can complete the stacking process in 10-15 minutes (basically saving yourself about a days worth of work, compared to mortaring between the blocks). Filling the cores and rebar would be recommended with either process.
                          RT
