Hi team from Oz,
I have enjoyed many hours so far looking at the great work going on, WFO's seem to be the biggest thing in Oz since beer was discovered
I plan to cast a refractory dome igloo shortly over a sand mould with a single brick arch at front with an embossed design added
My querey is the vent so I can choke the oven as per many designs around this site fitting in with my layout
I assume I may need to cut the centre top bricks to allow a chimney vent to effectively choke using the oven door, but if so, how do I attach chimney
( stainless steel flue ) as this is only a single brick arch
I can insert a chimney mould creating a seat for the chimney prior to casting but this will probably place the chimney too far back unless I can get it to sit hard up against the arch or build cast higher at front to set the flue
I am attaching a sketch of my dilemma & any advice will be greatly appreciated, I will have the base built over the next few days & plan to cast sometime during the next 4 weeks
Cheers,
Phil
Cheers,
Phil
