Fire brick mortar
  • Carleton
    • Apr 2009
    • 3
    Fire brick mortar
    Hi, I am looking for some help with the thicness to apply the mortar between firebricks, the guidelines indicate 1/8" maximum, but It will need to be thicker towards the outside of the dome where the bricks splay out.
    Is it okay to use a thicker joint here.
    I would welcome any help
    Carleton
    Re: Fire brick mortar
    Yes you can use a wider joint at the outside, you will need to unless you go crazy with cutting and fitting. What mortar are you using?
    • Carleton
      • Apr 2009
      • 3
      Hi Thanks for the reply, I am using Vitcas heatproof mortar,
      Carleton
      • DrakeRemoray
        • Mar 2006
        • 1215
        From the Victas site:
        Victas heat proof mortar is suitable for all kinds of INTERIOR use, but must not to be used outdoors.
        This looks like a premixed air-set product. Some people have used this successfully, but it will remain water soluble. Better to get a dry refractory product if possible...
        My Oven Thread:
        • Carleton
          • Apr 2009
          • 3
          I will look for a dry refractory product as suggested, not easy to find in the Uk so far, Vitcas assured me it would be okay as long as it was weatherproofed.
          This is a great site, really helpfull.
          Carleton
          • james
            Brick Oven Merchant
            • Mar 2005
            • 4648
            I'm with Drake on this.
            It's very difficult keeping an outdoor oven dry -- no matter how hard you try to weatherproof it. The issue is that the binder that holds the mortar together comes apart when it gets wet. Not good.
            • MK1
              • 123
              Doesn't burning the wood and baking produce water vapor. Is it enough to damage the air dry mortar or are things too hot in there?
              Mark
              • james
                Brick Oven Merchant
                • Mar 2005
                • 4648
                It's the rain, fog and mist. The mortar can't ever be exposed to water.
