I've just ordered my 15x20 FB stone. I've crawled all over the forums, and thank you all for all the useful info. But I do have one question that remains unanswered: how hot is *too* hot?
My ancient 1962-vintage electric oven will hit some unknown temp > 700F. The thermostat is skewed, thankfully predictably. Until I figured this out, I was burning stuff to a crisp by setting the temp to 500F; turns out 425F on the dial results in 500F, and 500F on the dial results in 700+F.
The same is true of my gas grill. The other day I put a reliable oven thermo on the cooking grill surface with the sensor about 1" above the grill. With all 3 burners on Medium, the temp hit 650F. You can imagine how hot it gets with all 3 burners set to High.
Because neither my indoor oven nor my grill have the thermal efficiency of a commercial pizza oven, I am going to lose a lot more heat when I open the oven/grill to put the pizza in. But the stone isn't going to lose nearly so much heat. Thus my concern is that if the surface temp of the stone gets too high, the crust will burn before the toppings are remotely done.
I've seen a lot of mentions here of 550F, but that seems to be based on an assumption that this is as hot as most ovens go. It isn't clear to me whether 550F is a desired target temp for pizza stone surface and oven air temp, or if it would be better to go even hotter.
I know this will vary based on dough hydration, thickness, desired outcome, etc. I'm just trying to get a general guideline. For what it's worth, I like crispy thin crust pizza.
Thanks for any pointers. I know I'll be experimenting; I just want to ruin as few pizzas as possible before I get it right.
