Sorry, I know some of these are a bit redundant, but I am new and have a small brain. I plan on using 2x8's to make a form for my hearth.
1. If I put down 3.5" of concrete with rebar is that good enough for strength? (54"x54" square with a span of 42")
2. If I fill the rest of the form up with vermiculete, is that enough insulation?
3. Then I put my fire brick for the floor of the oven on top of the hearth. Can I use splits and lay them "flat" or do I need to lay them on edge to get enough mass for the floor?
T.I.A.
Joe
T.I.A.
Joe
