Hello,
I am in Northern California, planning a 42" oven for the backyard. I will be using 8" wide CMU for the base support and a concrete slab/insulated concrete slab for the dome hearth base. Outside the oven dome I will use 4" wide CMU to build the walls outside the dome which will be faced with a stone/brick combo.
My questions are regarding the Pearlite or Vermiculite insulating parge over the dome and the mix used as the insulating base
Also, could someone provide a link to some build pics showing a dome insulation parge? I tried doing a search here and got so many threads that I kinda just kept going off topic checking things out!!
Thanks for any help, Eric.
- Is one better than the other (Vermiculite vs. Pearlite)
- For the hearth base, what mix do I use?
- For the dome insulation parge, what mix do I use?
- For the dome insulation parge, how thick?
