Everyone in here seems to use a spherical dome as opposed to an elliptical shape. Is there a reason for this? I've noticed a few threads whereby people suggest lifting your pizza towards the top of the oven when you are done (well, almost done) to crisp the top up a bit more; but wouldn't the same affect be achieved by building a lower dome?
I am currently drawing plans up on paper (I can't work out how to use QCad... if only Ubuntu had a mechanical drafting program) to work out the brick count and taper angles on the bricks, and need to decide on a dome shape before I can continue. I thought a round based elliptical vault dome would be good because it provides a more even heat from the top of the oven. What are the advantages and disadvantages of available designs? What -are- the available designs?
