Hi all,
I'm from South Wales in the UK and in the process of building my pizza/bread oven. I have a problem! I hope someone can give me an answer..........
Can I use large porcelain tiles as a base for my oven, I have standard red brick as my main base (I understand that I should be using fire bricks but they have been so hard to get hold of and I've had a week off to try and get the oven done!) The red brick has been laid on clay and sand so I just want to use the porcelain tiles as a top, laid in clay and sand so I can take them out if needed, what I want to know is if I can use a large porcelain tile on top, 1) to protect 2) given the heat properties of porcelain to hold the heat better?
Any help would be most appreciated as I've had such a nightmare sourcing materials you wouldn't believe!
LM
LM
