Hi all,
I'm hoping to avert an oven disaster in the making! Just to put you guys in the picture - my name is Geoff, I'm from Wales in UK and I'm trying to build a pizza/bread oven. I have been reading "The Bread Builders" and have tried to follow the instructions as best I can but..... I have made a few changes that I thought wouldn't pose a problem but after reading just a little on this forum see that I may now be heading for trouble.
I my wisdom! I thought using 10 concrete lintels across the base of my oven would be a much better support than using the rebo bars (that I was having trouble getting anyway), on top of them I have used a vermuculite/concrete 3 inch slab for insulation. I need to know if this would be ok as a base, I'm going to try and post some pictures when I work out how (mabe best put them into my gallery)
My next bright spark was to listen to general information I have recieved from brickyards etc in relation to bricks, the problem being that I have had so many issues trying to get hold of proper fire bricks, that in the end I put grade B(more dence iI was told) red brick with three holes in them as the base for the fire and was intending to use them for the dome as well, I have set them into 1 part clay and 1 part ciln sand with the outer last ring of bricks set with more sand a little cement added to the mixture (10 sand:3 cement:1 1/2 fire clay)
Hope I'm making sence here?
I assume from what I have read on this forum that these red brick with holes in are no good for the base but I was hoping not to remove them but instead use them as another insulation layer which I could place proper fire bricks onto, does anyone know if this would be a reasonable thing to do?
I'm going to try a post some pictures to give a better idea of what I'm talking about!
Many thanks
Geoff
Many thanks
Geoff
