Re: Medium vs Fine grade Vermiculite?
I do not know about freeze-thaw properties, but you do not need any block to augment the strength of the support slab. A 4" thick slab with rebar spanning your block stand is sufficient. It might be advisable to let your support slab concrete set up a little (next day) bit prior to pouring your vermicrete insulating slab. Vermicrete dries to a firm, but spongy texture that can be easily scraped away with a fingernail, but is plenty strong to support a floor firebrick lying on it's side.
