Re: Red Bricks and Mortar
"So you tapered tapered bricks? While I've got some tapered ones I plan to halve, I am still undecided whether to cut once or four times per brick. Was it worth the trouble? I like the idea but ...."
The dome curves in two planes so you will need a "beveled taper". Just start in on it. The first 3 or 4 courses you can get by with rectangular bricks. Above that you will soon start to see why you will need the beveled cuts. It's actually easier than it sounds when it's all there in front of you.
I would not cut them ahead of time (except mass cutting into 2/3, 1/2, 1/3). After that cut them as you go. Soak the bricks before cutting to save wear on your masonary blade.
