new oven
  • new oven
    I have built a new oven and heard that the inside dome should turn white once fired up. I have had a couple of fires and it remains black? Is that normal?
    Thank you
    Re: new oven
    Just means you need to build a bigger, hotter, longer fire. Post some pics of your oven too!
      Re: new oven
      Is it okay to cook in with the black soot?
      Thanks again
        Re: new oven
        But during the curing process your low temp burns will keep the dome black for the most part.
        George
        My 34" WFO build
          Re: new oven
          Just uploaded a picture!
            Re: new oven
            sorry I am new to all of this. I don't understand what you mean by curing process?
              Re: new oven
              The oven looks good. I linked the image to this post so it is easier for people to reference.
              Refer to the pompeii oven plans for the curing process. In brief it is the process of a series of fires increasing in intensity over the course of a week or so to force moisture out of the oven dome.
                Re: new oven
                Can you cook during the curing process?
                You guys are really helpful
                Thank you
                  Re: new oven
                  Yes you can!! Pizza temps usually dont occur until close to the end of the process but roasting is great in the mid temp ranges.
                    Re: new oven
                    Sure thing. In many instances you will not fire the oven to high temps so you will be cooking in the black dome.
                    Here's a pic of spareribs I did during one of the low temp curing fires:
                    George
                    My 34" WFO build
                      Re: new oven
                      wow.................
                        Re: new oven
                        How do you limit the smoke when firing up the oven. I had a lot of smoke come out of the oven. Don't want to upset the neighbors??
                          Re: new oven
                          Smoke mostly comes from wet or wettish wood until it drys enough to fully combust. Once your fire is in full swing you should have very little smoke. Most likely you will get some smoke when you first light up
                          Peter
                          Member WFO-AMB=WW
