If I can figure out how, I will post some pictures but here is my "design" and attempt at an oven. Built on my pool patio so I did not dig any footer.
Two layers of cinder block as base - about 20 inches from ground
Used concrete pavers to give me flat surface on cinderblock base
Bought 24 fire bricks and used them to build oven base on pavers
Built up with standard solid bricks for sides of oven - 1 brick thickness (everything dry stacked so far).
Made a roof using fireclay/sand mixture and a homemade 2"x4" form about 2 feet by 3 feet by 2-4 inches thick. Used a concave disk to make "dome" on underside of formed roof. After curing for a couple weeks flipped it over and set on top of dry stacked bricks.
Took roof off and mixed a sand/fireclay mortar. Put a layer on top of drystacked bricks and reset roof so it is sealed.
Used mortar to set a second layer of bricks on all sides thereby adding mass and sealing oven interior.
Dry stacked another layer of bricks on roof (these bricks are concrete bricks not clay bricks - but cheap).
About $200 in project (I looks sturdy but not very pretty - I am not a mason I can tell you). About 2 days all told laborwise.
Fired first time last weekend. Fire burned nicely - for about 2 hours(start to finish). Started small and moved to oak chunks and pushed to back. Top was very hot sides not so much (outside that is). No smoke to speak of seeping from oven. A crack developed in roof but does not appear to be a structural issue yet.
So I used my kitchen thermometer and got about 450 in oven after raking out fire (using bricks drystacked as "door"). Want to get one of those lazer heat guns.
Went ahead with bread - bread got about 2/3 done in about 1 hour and I had to transfer to indoor oven to crisp it up and finish it. But it did get great oven bounce and ended up tasting great.
About 10 hours later interior was still about 250 - top was warm and sides were as well (about equal heat this time).
I suspect I may have to build a brick roof ultimately - but nothing ventured nothing gained. I also think I may not have fired oven long enough to get a good bake out of it. I am going to try to fire it longer and with a stronger fire this weekend.
If that does not work (and roof still looks ok), I may try to mortar real bricks on the roof top to absorb/store more of the heat (similar to the sides). Finally, I may have to insulate the whole thing somehow.
Any thoughts/advice or predictions?
