Hello All,
My build is a self designed 38" oven of brick. I'm ready to stack blocks for the top slab and need a recommendation for rebar reinforcement, or none at all. The inside, unsupported dimension, is 36 inches by 48 inches. The outside is 52" x 72". The slab will float without tie-in. The ground is stable, no frost heave and no geological faults.
The front opening will be supported by one row of block on top of two iron angles. I'll be using high strength 5000 psi concrete mix in bags from the local materials store. The form will be made of 2" x 6" wood but the slab will be 3 1/2" thick and poured over 1/2" cement backer board. There will be a temporary wood board placed in the center to hold up the backer board as shown in some fb forum photos. Am I doing this right or do I need rebar reinforcement? There seems to be controversy about this.
Second question: The materials store offered a variety of sand in grade sizes from 40 to 120 for the fire clay mortar. Is there a preferred grade for oven mortar?
I appreciate your guidance in advance.
Cheers
Cheers
