Hi All,
(I moved the thread to this new location)
The oven is nearly done and we've framed the outside with steel studs and Hardibacker board. It is the type used for bathrooms and wet areas. Could you recommend the steps for placing stucco on the backer board? Does it need primer, metal lath or chicken wire?
The enclosure has a peaked roof and looks somewhat like a childs play house. The sides are 52" x 60". It will have metal roofing. Is ventilation of the roof area necessary or can I close up the seams all around when I apply stucco? Just wondering if moisture could get trapped inside the enclosure and cause a problem. If a vent or two is necessary could you recommend the size and correct placement?
Cheers,
Cheers,
