A newbies survey of the Forno Bravo treasures hiding in the archives
This is a sticky topic.
  • mrchipster
    • Apr 2010
    • 1502
    #91
    Re: A newbie?s survey of the Forno Bravo treasures hiding in the archives
    Instead of trying to place the bread into the Dutch oven (which I found hard to do) I place the bread on a hot baking stone and cover with the up-side down Dutch oven.
    That way you do not disturb the bread as much and the results have been great. Except for one time when I pinched the edge of the dough under part of the Dutch oven and created a little crunchy crusty bit that hung out. But that bit was tasty also. So ..... no problem. This technique works in the WFO also when you are making a small batch or single boule but I use it most often in the house oven when making a loaf or two for the family.
    Chip
    • Lburou
      • Dec 2010
      • 1165
      #92
      Originally posted by mrchipster
      ...That way you do not disturb the bread as much and the results have been great....
      Quite so, that challenge is the reason I pour the dough (after 18 an hour ferment) into a mixing bowl or another dutch oven, lined with parchment paper. The (covered) dough rises 2 more hours . Then, I take the four corners of the paper, lift the dough, and place it in the preheated dutch oven (with the paper). Easy Peasy! :-)
      Of course, this all works well the day after baking pizza, pizza, pizza!
      P.S. Thanks for the pdf's Mike!
      Lee B.
      DFW area, Texas, USA
      • owensrj1
        • Oct 2014
        • 2
        #93
        hey Lee.
        Check out these wood fired oven builds they are professionally done. i am tring to follow the way they have built and Ken524, K79, Dino and more to make one great oven
        • mrchipster
          • Apr 2010
          • 1502
          #94
          Mid month bump to one of the best places for a new builder to start their study of fine oven building.
          Start at post #1.
          Chip
          • Lburou
            • Dec 2010
            • 1165
            #95
            Mrchipster posted his design for a cutting board to assist in cutting your bricks during your oven build HERE. :-)
            Lee B.
              • 5261
              #96
              First post in quite a while, so I am helping llburo keep his newbie section moved to the front.
              • SableSprings
                Moderator
                • May 2009
                • 1310
                #97
                September bump...try making a fruit crumble, pumpkin pie or savory bread pudding in your oven this fall. WFO heat does a nice "crust" with all, just don't start with a cold, glass pan and use an inverted cookie sheet as a platform if your hearth temp is a bit too high. Also try some apple or tomato tarts to use up some of the goodies being harvested now...(unless you're in the southern hemisphere )
                Roseburg, Oregon
                • RichW_SC
                  • Sep 2015
                  • 2
                  #98
                  Newbie here and thanks for this thread. My brain is absorbing as much as possible until the lightbulb goes off. Plan to break ground this week. Excited!
                    • 5261
                    #99
                    Oct bump for a great thread for new and old......thx Lburou
                    • NCMan
                      • Jan 2014
                      • 846
                      #100
                      Glad you dried out enough to get started. Best of luck to you. Keep us all posted.
                      My Build:
                      • SableSprings
                        Moderator
                        • May 2009
                        • 1310
                        #101
                        Here's an update/info post to keep this thread near the top of the list. The link below is to page 3 of the "Favorite pan, tool or gadget..." thread. I uploaded a pdf of my favorite dozen tools for baking & working a WFO and attached it to post 45 on that page...hope it might be an additional "food for thought" resource and appropriate here.
                        Roseburg, Oregon
                        • ivancito
                          • 155
                          #102
                          thanks hopefully this will be saved
                          • tehodler
                            • Jul 2019
                            • 3
                            #103
                            Leaving my first comment in an old thread so as not to bother anybody. Aslo it's a really good thread! Now I'm off the Introductions forum to post a comment there.
                            • jer1atric
                              • Jan 2021
                              • 7
                              #104
                              Just joined today, this is exactly the post I was hoping to find! Thanks so much.
                              • Lburou
                                • Dec 2010
                                • 1165
                                #105
                                Thanks! Your response is the reason we took the time to make the post and update it, (while it was still possible to keep it current). Good luck on your journey. :-)
                                Lee B.
