Hello all,
Over the year or so i have read many books and manuals on pizza ovens and put the following question for debate. (i expect a good heated one
Can we use the poor mans Refactoring cement as a castible???
What ya recon???
- All the early clay ovens of history used about 3 parts sand to one part clay and have staisfactory heat holding ability... similar to the poor mans mix so will have the heat holding ability
- Granted that this recipe will not handle direct flame contact well it is still recommended to have a fire brick floor and perhaps a ring or two of fire bricks for the first part of the dome.
- In New Zealand the fire bricks are in the order of about $5-$6 NZD each which can make an oven too expensive to build. where as the poor mans refactoring cement costs are fairly low and easily availible. also suppliers here hardly ever seem to have any knowledge of their firebricks and try to sell you any old rubbish.
- A simple geodesic dome mould could be made and tiles poured then cemented together or simply slapped and slopped over a news paper coverd sand mould.
- the main reason i would not use a clay oven is the fact that the oven needs to breath (i.e. un sealed) or otherwise the condensation builds up and the oven collapses also the mix is very soft. also as you can't seal it you would need to build a roof over the oven to protect it from the weather.
- My hope is that the poor mans mix will be the best of both worlds. Cheap easy but practical.
What ya recon???
