Re: Oven sizing question
My 42" (interior diameter) Forno Bravo has a door 16" high. Three 12" pizzas fit just fine, with plenty of room for the fire, but, as others have said, I doubt you'll actually have 3 in at once. You could fit 4 in if you wanted to, and they could be larger than 12", but it is extremely unlikely you would ever do it. It would take a professional to handle that many at once; you'd have to be putting them in every 30 seconds to get four in before the first one is done. They cook in about 90 seconds, so there would be no significant wait between pies, even if you did them one at a time. I prep while my son cooks, and we almost never have more than two pies in the oven at one time and do 16 pizzas in less than 40 minutes.
A 23 lb turkey fits in just fine, or 20 or more pounds of bread. I don't know how wide the door is but it's a lot wider than any duck. Or turkey. The door height is the limitation for your vertical ducks. Due to the laws of physics or something equally complicated, your door should not be higher than a certain percentage of your dome height, and your dome height should not be greater than a certain percentage of your floor diameter, so, unless you build a really huge oven (which would take a really huge amount of wood a really huge amount of time to get up to temperature) you won't be able get the ducks through the door vertically. I can get a beer can chicken in vertically, but I there wouldn't be room for a duck hanging from a rack.You would probably be able to rig something up so you can slide them in horizontally and then hang them up from a rack inside the oven, or something, I don't know.
Follow the Forno Bravo plans carefully; vary the dimensions at your peril. It seems to me that a very high percentage of people on this forum who have performance problems have failed to follow the plans. These ovens have been built for thousands of years, and the optimal dimensions are pretty well settled. Varying them can lead to poor performance, excessive time and wood needed to get to temperature, or both.
Karl
Karl
