Has anyone used, or thought about using, styrofoam panels ( panel covintec - Google Search ) for the insulation base of an oven?
Due to the availability, or lack thereof, along with the cost of certain items where I live part time in a small town in Mexico I am thinking out of the box a bit (as far as the traditional methods detailed throughout this great forum).
That being said, my current plans are to go to a local adobe brick manufacturer and ask them to make adobe blocks with molds I will provide them. Typically here in Mexico they either make a cob oven or use blocks made of adobe clay/soil. The shape of the blocks used here for making dome style ovens are called "cola de pato", which is basically an isosceles triangle with the corner (point) of the long end cut off parallel to its opposite side (think of a wedge with the point cut off). Using this form of block uses less mortar. Oh, the mortar I will be using is simply adobe clay/soil.
My issues here are that the town is so small, along with the hassles of obtaining vermiculite/perlite etc. I am trying to think of alternative methods and materials to construct my Pompeii style oven. I'm thinking of constructing an isolated base, as typically done for brick ovens, but using a foam panel (see link above), reinforced with rebar, with a 1 1/2" layer of regular concrete on the top and bottom sides of the panel. Then a thin layer of beach sand on top with wine bottles (yes, I love red wine with my pizza) laying down on their sides with about 1" of beach sand between each bottle (another thermal layer) and then a thin layer of beach sand on top of the bottles. The final layer (the oven floor layer) would be adobe clay/soil mixed with sand (not beach sand) at a 30/70 ratio (the same ratio used to make adobe blocks). It is my understanding, after reading volumes of information in various forums, insulating all sides of the oven is crucial for the efficiency of the oven. Is this insulation overkill or ?
Additional info: The dome of my 42" oven will be constructed using the "cola de pato" style of adobe blocks as mentioned above with an 8" wall thickness. After the adobe block dome is constructed (with a hybrid interior dome height of 18" along with 9" vertical side walls) my plan is to coat the dome with a 6" layer of cob (adobe clay mixed with either sawdust, straw or coffee bean husk (this is the insulation layer). The final layer will be a 1 1/2" layer of adobe and sand mixture (kind of like a plaster coat).
Yes, I'm basically making a cob oven but using adobe blocks instead of the adobe clay.
Any advice you folks can give me would be greatly appreciated.
