Hi, I have been searching the FB forum for topics about how to deal with a soaked oven after a spell of rain with poor waterproofing. Lots of posters said that while it is a pain, a soaked oven can be rectified with a few steady fires. Is it the case that the insulation blankets can be soaked and dried out numerous times or will they deteriorate pretty quickly?
I am going to use this Rockwool 159 blanket. This blanket resists temperatures up to 1200F and absorbs water at less than 1 kg/m? (not sure if the water absorption rate is good or bad).
Cheers,
LEAO
Cheers,
LEAO
If you haven't put the blanket on yet, why are you worried about the affects of water? If you do a good job - it's a non issue. I would worry more about burning your food.
