Hi all,
I am on my II attempt to build a (almost) portable WFO; my first attempt with clay did not work and now I am doing this a little bit seriously.
I first tried to emulate @pizzahacker and put a dome on the weber grill, but I tried to be cheap and failed.
I'm now working on a solid iron table 28" x 28", I secured a double layer of rebar grid and poured a three inch cement base. 18 fire bricks for the base and cooking floor and some more for the vertical walls.
And I am at the DOME point again. I have the castable and I want to mix it with as much perlite as I can so I can reduce the weight. my question is: about proportions, how much perlite can I add without compromising the mix? And how much more water will I need for the mix? the Mizzou seems to require very accurate measurement for adding water... any hints?
oh, by the way, I am going to lay 2" of the castable on top of the 22" weber, pop out the metal once the cement sets. I plan to sit that on the bricks and adding another layer to seal the bricks. Insulation on top and some more perlite/cement on top of the insulation layer.
WILL IT WORK?![Smile](https://community.fornobravo.com/core/images/smilies/smile.png)
I am putting pictures on this public album!
https://www.facebook.com/media/set/?...8&l=8053308b49
WILL IT WORK?
