Hi all,
Newbie here just starting down the route of the pizza oven triathlon!
I'm planning on using a the bricks left over by my builder during my house build (around 500) to create a built in BBQ, pizza oven, and bar fridge with a stainless steel bench area between the BBQ & oven in my alfresco area. The BBQ, bench top and beer fridge are pretty easy, and I can do myself, with a little help from a brickie friend to lay the bricks professionally. The oven however is causing some headaches. I would like to build a brick one from scratch, render it and maybe mosiac tile the render, however the Mrs wants a stainless steel one for it to "look nice" (The steel oven would still be wood fired, but just not bricked). If I build one it would need to be pretty small depth wise (less than a meter), but width is not so much an issue as I could even encroch over my beer fridge space if needs be, as the fridge will be below the bench top.
Anyone got any ideas on the style I could use for a short and fat oven, or indeed if the Mrs is correct and a steel oven will do the same thing?
