I've been planning to build an oven for awhile, and various other projects have resulted in me owning a cement mixer and a 2.5hp brick saw (from harbor freight).
My next decision is placement, it strongly affects the time the build will take. I live on the side of a hill and my level land is minimal... think "postage stamp" yard. This is where I would appreciate comments.
There is a spot that I could pour a slab, and build the oven away from everything else. I have a little concern that it would look a little "out of place" at that location, and would start to make my small yard "too crowded".
I could excavate into the bank behind the lower deck and place it back into the bank. This would improve the look of the bank but would require a lot of dirt removal and a retaining wall. This would add a lot of time and cost to the project.
Finally, I can see building it on the existing patio under my upper deck. This 12x24 space already has a 6" slab under it, and could end up being a nice covered outdoor kitchen. The deck is about 12' above the slab.
The questions are:
Most of the ovens I see stand apart in the yard, is this important?
Aesthetically, building it back into the bank would be a great solution... but it would be a lot of work to do that. Can the oven be part of the retaining wall, or is this asking for trouble?
If I built it under the upper deck, I would either have to run the chimney up through the deck or have it bend rearward over the top of the dome so it could then turn vertical outside of the deck. Is this a problem?
Sorry in advance if my descriptions are hard to understand. Thanks in advance for thoughts and ideas!
The questions are:
