Ash instead of Vermiculite
  • Ash instead of Vermiculite
    We use our wood burning stove at home quite a bit, and so now I have a large stockpile of regular ash made from burning wood. I am about to insulate around my dome, and I was going to use vermiculite, however, since I have all this ash I was thinking of using it to save money. Recommended?
    Also, is it possible to mix ash with the heat resistant mortar?
    Re: Ash instead of Vermiculite
    Vermiculite is pretty cheap. Ash may work, I don't know, but I wouldn't cut corners on the insulation. You are only going to need 2-3 bags.
      Throw the ashes on the garden and mix in or on the compost heap.
      You need lots of entrapped air to make insulation work properly, ash will compact.
