I am getting ready to start my outdoor kitchen/oven. I live in pennsylvania. Do I need to dig a footer and put my foundation below the frost line like I would for any other structure? I dont see much mention of doing this but dont want to be dealing with the structure heaving after winter freeze cycles either. I would rather not since it is so much extra work but would do it if enough people have had trouble.
Why dont I need to dig footer below frost line?
Re: Why dont I need to dig footer below frost line?
If you were to tie a structure into another structure, both would need footings. Your slab will raise up less than an inch in winter then settle back down when the mild weather returns. The example I use is sidewalks: do you ever see the city making a foundation for a sidewalk? Make sure your slab is thick enough and use plenty rebar and make sure you remove all the topsoil and make a packed gravel base. I always put geotextile below the gravel because it stops the gravel from sinking in to the soil.
I am going to differ from the above two because I am planning a footer similar to that of dbhansen. I was actually talking to a friend today who does masonry here in my area and it was his strong recommendation to put a footer below the frost line of any load-bearing slab. And by the time you figure in all those bricks and a concrete hearth it is my opinion that there will be quite a load on the foundation. Our frost line out here is 36" so I am probably gonna go down 48" and start with a foot of compacted gravel then go to an 8"x10" footer then build with cinder blocks until I get to where I need to be. Like I said I am just stealing dbhansen's idea so check out his build to see what I mean.
Originally posted by Mingy View PostThe example I use is sidewalks: do you ever see the city making a foundation for a sidewalk? Make sure your slab is thick enough and use plenty rebar and make sure you remove all the topsoil and make a packed gravel base. I always put geotextile below the gravel because it stops the gravel from sinking in to the soil.
Nate : A footer will add to the load on the soil below because it will add tremendously to the amount of weight which has to be supported. Also, chances are the load per square foot will be even higher because the entire structure will be supported by a smaller area. You should always check with building codes or structural engineers rather than trades. I have seen/heard trades recommend all kinds of things which are contrary to good practice. Here in Canada, where we know a thing or two about cold, many structures are slab on grade. I have a 40x24' garage slab on grade, and in the summer I'll start construction of a 100'x 40' workshop. Both slabs were 'engineered' only because the city needed to be sure the structures could take the snow load).
Mooch - concrete cracks, its a fact of life. The best defense against serious crack which could affect structure is rebar. I put 6" mesh and 1/2" bars around the edges where it will have to support the blocks. Rebar holds things together and makes the concrete much stronger. Proper placement is important: about 1/3 of the way off the bottom.
Laku - I would like of see pictures of that. The strength or durability should not be affected by a foundation unless their is real funky soil. Here they put a 16" slab with 1" epoxy coated rebar in the walkway for the commuter train. You could park a battleship on that slab. I suspect the reason they did so was because it isn't their money.
Here are some relevant links
Slab-On-Grade Construction (CMHC Canada Mortgage and Housing Corporation)
There are loads of others. Note that the insulation shown is so a heated dwelling doesn't lose heat to the ground.Last edited by Mingy; 04-06-2012, 06:22 AM.
Originally posted by Mingy View PostLaku - I would like of see pictures of that. The strength or durability should not be affected by a foundation unless their is real funky soil. Here they put a 16" slab with 1" epoxy coated rebar in the walkway for the commuter train. You could park a battleship on that slab. I suspect the reason they did so was because it isn't their money.
But I think there is a point in making a proper foundation. The way I figure it is that although you might only get inch of frost heave, it might not be uniform under your slab. which in turn might lead it to being little slanted on one direction, causing a lateral strain on your oven/structure. Which in time could stress it beyond breaking point. I'm not an engineer so take it with a grain of salt.
How ever what I do know is that building code in here require proper foundation to all buildings, with base below frost line and/or insulation layer to prevent frost from forming under the building, for any house/building.Last edited by Laku; 04-06-2012, 11:28 AM.
Frost heave is caused by frost, freezing water in wet soil. No water, no frost heave. Hence the layer of gravel under the slab, to drain away moisture. If your oven is at the lowest, wettest place in your property, then this won't work, but it does work most of the time.
The exceptions are for extra tall, or non-free-standing structures. If it's part of a building, it needs footings like the building.
Laku I see what you are saying: they make sure there is a solid foundation for the sidewalk. I thought you meant they did below the frost line (about 1.5M) which they never do here for sidewalks. Obviously, you want a good base for a slab, but, if you think about it, the slab riding up or down a bit will not put any more stress on the slab than the weight bearing down. If your slab is properly made with rebar and mesh, it should be able to support the weight either way. If you think about the suspended slab the oven sits on, it spans about 2M with all the weight of the oven on it, and it should be (and is) strong enough to support that. The bottom slab has the added advantage of being supported across its area, so there are less stresses.
As I said, they build large structures here slab on grade, insulation optional (I believe code calls for it for a heated building for the same reason you have to insulate the walls).
Mingy,
you make a very good point. Thanks for the input. I was actually considering a slab like the one in the diagrams you linked to. I will really have to reconsider after your comments. I had never really thought about talking to an engineer so thanks for that idea. Now I just need to track one down. Thanks again. A question for you though. I believe those are monolithic slabs (I was under the impression that was another name for slab-on-grade) in the links you supplied. Whatever their names are, do they need to go down to the frost line or do you just go down a bit and insulate? Thanks again for your help.
Nate
Nate
It depends on the structure. For my garage, its about 12" thick around the edges (where the structure weight is) and about 6" in the middle. I made my oven slab about 6" thick around the edges and about 5" in the middle. I put 6" mesh and 1/2" rebar as well. I think I put rebar 12" on center in a grid with 6" around the edges. Rebar is cheap.
So, the process I used is: strip off the topsoil. I live on a farm, so thats about 12" to 18". If you live in a suburb, they usually only leave a few inches of topsoil. So, I had to fill in with gravel, which I compacted. Good thing I have a tractor with a loader and a backhoe!
I don't believe you have to insulate the slab for an oven. If you were building a house, or building a heated garage, you'd want to so you don't spend money heating the ground in the winter.
To find an engineer, you might look for a civil or structural engineer. First I'd call or visit my town's planning department and speak with a plan inspector or building inspector and see what they have to say. They also are likely to know an engineer in your area.
The folks in my town are pretty helpful so I ask them stuff all the time. You may be hesitant to discuss your oven, but here a structure less than 100 square feet doesn't need a permit. So if I had any questions about building a storage shed, for example, I'd call up and say I want to build a slab on grade (nobody would expect a foundation for a shed), do you have any suggestions, example plans, etc?
When I build my house, every now and then they would pull out a 'how to' sheet of paper (like how to tie wood to concrete, how to install a vapor barrier properly, and so on).
Speaking of which I usually put 6 mill plastic down before I pout the concrete because it keeps the water/cream with the concrete.
Originally posted by dmun View PostFrost heave is caused by frost, freezing water in wet soil. No water, no frost heave. Hence the layer of gravel under the slab, to drain away moisture. If your oven is at the lowest, wettest place in your property, then this won't work, but it does work most of the time.
Insulation below and around heated(and cold) buildings in here is added to prevent frost forming below the foundation and to act as first capillary break. The idea as I understand it is that you insulate around the house (as well as beneath) as far away from the walls as the frost line is deep (or more don't remember exactly). That will prevent the frost ever reaching below the house, thus preventing any damage by frost heave.
So I was able to track down a structural engineer about a slab (luckily I have a friend who works with one and it didn't cost me anything). I sent him my google Sketchup drawings and he said a 6" floating slab with rebar would be plenty. So now my plan is to lay down 12" of gravel (or maybe road base) and then build a floating slab on top of that. This should cut way down on my costs. Thanks again Mingy for the suggestion. I owe you one.
Now to just line up the equipment to get my build started...
