Re: Oven Build in SC
The protrusion depends on your build and vent design. Look at mine compared to Russell. Russell has the arch protruding so it can support the rear of the chimney as mine was short and didn't leave room for support and required more work on the vent. (wish i would have made the arch protrude more.) A larger protrusion will require more than a half brick (normal firebrick size) I believe Russell had some larger brick, but mine were standard. I just used a 1/2 brick.Are you planning a semi-circular arch like Giannis? Karangi dude, Sharkey, Amac, and DJ's are all semi-circle. Before i steer you wrong, let's make sure that is the design we are talking about.
Tracy
Tracy
Can?t wait to get at it after work!!
