Re: Oven Build in SC
On the IT ?
i would fix that now and get that set so you don't have adjustments later. If you adjust the tool by shortening later, the bricks will not line up with the course that was set using the longer measurement. Post a pic of your IT setup if you can. You can take a brick out or mount to 1/4" masonite or even screw to a brick and sacrifice that brick. I know others have done the change on the IT, but you will have so much going on in those upper courses, you really dont want something else to keep up with. And, your dome will change its curvature and could make tying the arch in even more difficult. Also, i would suggest making your inner arch template now and setting the arch bricks on it as you try and figure out those arch bricks. It will really help visualize the setup and the distance that you have from the center of the oven.
Tracy
This a pic from the octoforno build of the setup.
On the IT ?
Tracy
