I'm moving into a new old home with a large patio in the backyard. It is made of regular clay bricks laid on the flat side. I believe they are loose-laid directly on top of the dirt, which here in the desert is very hard, really more like sand. No mortar that I can see. I haven't checked the grade to see how it slopes, but the few times a year when it does rain, the water should quickly soak through the gaps between bricks and into the sand. No seismic activity out here, nor any other severe environmental effects, other than extreme heat, which isn't harmful to masonry.
So could I skip the concrete slab and just start laying slump blocks right on top of the patio bricks? The patio is raised about 12" above the "floor" area where I would be working, which would mean my slump block stand could be 12" less tall than the Pompeii plans call for
