In reading these differnet threads i have found many of the answers to my questions , but one thing I have not ran accross is joint finish on the inside of the oven . Are the joints struck ( smoothed out with a joint tool ) or are they just cut flush with the brick . I know towards the end you may not be able to reach some of them to finish , so maybe its really not important . Thanks.
Tags: None
Re: Joint finish ?
Jim -
Generally, builders angle the bricks so that there is almost no joint inside the oven. You can use a joint tool, but really you want as small a joint as possible
Re: Joint finish ?
If that is the case , what would happen if the bricks were dry stacked ? The cladding should hold everything in place , should'nt it ?My Oven Build
http://www.fornobravo.com/forum/f6/s...ult-18532.html
Re: Joint finish ?
The joints in the top of my dome are down-right embarrassing. I have stelagtites hanging from the ceiling!!! I wish I could do all over again, but guess what, it works fine! As a matter of fact, my oven is cranking right now! Cooking some wings and baked potatoes....
Re: Joint finish ?
I am building a barrel vault oven and want to lay the base bricks horizontally for 3 courses before starting the arch. I think I will put a small mortar joint on this "wall" just to hold them in position for the arch. Does that sound like a reasonable method?My Oven Build
Re: Joint finish ?
Al , I am planning on a 4 inch cladding . My thinking might be all wrong here , but living where the avg. temp is 40 degrees or below for 5 months out of the year , I am thinking that the mass will be to my benefit . Thoughts?My Oven Build
Re: Joint finish ?
4" extra thermal mass is a lot. It will take many hours for the heat to soak right through to that thickness. You would probably be better to halve the cladding thickness and increase the insulation.Kindled with zeal and fired with passion.
Re: Joint finish ?
I agree with David, in Minnesota it gets even colder, and I spent more on insulation and it is no problem keeping my. Oven warm for days after one pizza evening, and bringing it from 400F on day 3 to 800 or more for another pizza night takes less than 30 minutes.Originally posted by david s View Post4" extra thermal mass is a lot. It will take many hours for the heat to soak right through to that thickness. You would probably be better to halve the cladding thickness and increase the insulation.
I cooked all last winter and plan the same this winter.
ChipChip
Re: Joint finish ?
Al , my plan was to use regular concrete .
David and Chip , my plan now was to have 4 inches of cladding and 7 inches of loose perlite held between the cavity the outside wall and the cladding made . I am pouring the hearth tomorrow out of perlcrete . It is formed up at 5 1/2 inches thick .My Oven Build
