Hi, I've been working towards the barrel vault design in the bread builders book. I'm now up at slab height and I've decided to go with an igloo style kit. The design in my book as for 2" vermiculite/concrete underneath a 3.5" concrete slab in which sits a firebrick hearth. The refractory where I'm buying the kit tells me that the base is 50mm thick(fireclay I think) and to sit this on 2" vermiculite concrete. My questions are
1. Will this 50mm thick base have enough thermal mass or should I add maybe an inch of concrete underneath it?
2. I intend building the chimney out of red brick instead of firebrick to save money. Is this a good or bad idea?
Richard
Richard
can't actually blame her with the current rate of progress + I've grand plans for an all weather outdoor BBQ area where I can brew beer also.
