First, I built the dome last year and let it set for the winter, covered for the most part but it's been sitting in the weather (rain) all spring and summer. I cured it last fall and even cooked a few pizzas and other things. It worked rather well except for losing heat quickly for lack of insulation. I got cracks in the mortar but no smoke. I freaked out one time when I saw what I thought was smoke rising from the dome but it was steam from the dew cooking off the mortar. My question is ... do I need to re-cure dome now that it has been in the weather before I insulate it? In other words, have the bricks soaked in moisture, or do once cured, they stay cured?
Secondly, I've seen a lot of people put aluminum foil over the dome before adding the insulation blanket. Is that necessary? What does that accomplish?
Thanks for any help you can give me!
John
John
