Need opinion on best location
  • Need opinion on best location
    Hi everyone. First post of many to come. I designed my outdoor kitchen assuming I needed about 36"X48" for the WFO. After doing some reading here, I realized I was way off. Looks like I actually need about 65" x 78". Now I'm looking for some creative ideas. Here are a couple pics of what I've got going on.
    Thanks in advance.
    I've also started a blog for the construction of my outdoor kitchen located at DIY Home Projects | What I'm currently working on There are a couple other pictures on there but not much. I've just begun but plan to keep it updated.
    http://n8sbar.servebeer.com/
    Oven Thread
    Kitchen/Bar Thread
    Re: Need opinion on best location
    Hi,
    I'm no garden designer what so ever, but is it not possible to maybe redesign the layout of the kitchen "counter" and the chairs ? maybe utilize some of the space for the countertop ? and then keep it in the original place, i mean with entertainment, serving pizza etc.
    I would be quite unhappy with option A and B. But maybe we danes think a lot different when it comes down to it
    But i will for sure be following your build, the drawings looks awesome..
    Follow my build:
    https://drive.google.com/folderview?...Tg&usp=sharing
      I think the two main considerations are 1. Proximity to your kitchen
      2. Prevailing wind direction during cooking times.( this can be helped by a taller flue, but you don't want to cause your neighbours annoyance)
        Originally posted by Madsen View Post
        Hi,
        Thanks for the comments.
        I wasn't really happy with A or B either. I was hesitant to take up some of the bar top because I'm trying to make it like an actual bar. Meaning that large (70") kegerator shown in my blog will have to fit in it. I'm also adding an ice bin liquor well, ice machine, BBQ, sink, and more. I went back to the drawing board and came up with this:
        Keep it in the original position
        Change it to a 36"
        Chamfer the back two corners
        Lengthen the entrance to the bar slightly
        Doing this presents two new possible issues.
        1.) The outside of the oven (accounting for 4" of insulation and 4" of enclosure) is only 4" from a wooden fence.
        2.) Second, the ground level deck will come right up to the front face of the oven. The deck will be composite, but has wooden deck joists.
        Any issues with the above?
        Oven Thread
        Kitchen/Bar Thread
          Change it to a 36"
          Phew, it sounds to me that you need to buy the lot on the other side of the fence
          No, it truely sounds like a great area your building there. looking forward to the final pictures - if it was me, i'd prop be done no earlier than 2015
          Regarding the wood fence close to the dome, i guess its no problem if you insulate propperly. But I know you can spray/paint the fence with a non flamable paint. But on the other hand, the dome dosnt get that hot - its more the oven opening where you could spill the coals etc.
          But local restrictions can and maybe also apply, this you need to check.
          Follow my build:
            I forgot to post the updated layout. Should I create a build thread and ask all my little questions within the build thread, or should I post a build thread and ask questions in separate posts? I'm probably going to break ground this weekend.
            Oven Thread
            Kitchen/Bar Thread
              the first option is best.
              Cool location, look forward to seeing the progress.
                How much heat comes out of the opening? Too much to hang a TV over the oven? I have a TV over my interior fireplace but I suspect more heat comes out of the oven than a typical fireplace?
                Oven Thread
                Kitchen/Bar Thread
                  I think it depends on how well your oven is vented. I think most of us see at least a little smoke staining on our entry brick - so that is evidence of at least some heat loss.
                  Aside from venting well (which you should do anyway), you could fabricate a blast door that mounts to the outside of the oven, that might help to keep your "leakage" to a minimum.
                  The next time I fire up my oven I'll try to get a gage on how much heat is exiting the top of my oven entry....though given the season here, that might not be representative of your conditions. Here's a picture of our oven after 18" of snow on 1/5. Not to worry, we were back up and running - baking pizza and smoking a pork shoulder the following weekend.
                  Regards,
                  AT
                    I realize this is only my opinion, but......
                    Why on earth would you want a TV above the WFO???
                    It's going to not just simply compete with the oven , but it will overtake it as a focal point. I don't get it.
                    To your question, if you size the throat properly, you won't dump an excessive amount of heat out of the outer opening. So, you could *shutter* put a TV over it.
                    Old World Stone & Garden
                    John Ruskin
                      Just my opinion but I reckon that Stonecutter is on the money. The action in the WFO is the main game for me and my guests.
                      The design does look good though and good luck with it.
                      Cheers ......... Steve
                        Here's my latest rendering. I put the TV over the WFO just to upset everyone, lol. It's not final, just stuck it there for the time being.
                        Oven Thread
                        Kitchen/Bar Thread
                          You should keep it there. Then you could post a video of the screen blowing up, or the plastic dripping all over the hearth...after it burst into flames.
                          John Ruskin
                            I reckon you have the whole forum busting a gut laughing. Well done.
                              I started a build thread if any one wishes to continue following my build:
                              http://www.fornobravo.com/forum/f35/...tml#post168558
                              Oven Thread
                              Kitchen/Bar Thread
