New outdoor kitchen
  • New outdoor kitchen
    Started building my outdoor kitchen a few weeks ago, using El Dorado Stone prefab concrete structures. Then built a Pergola for some shade.
    Re: New outdoor kitchen
    Stone veneer
      more stone
        Pergola done
          Crossram,
          Are you buying the prefab concrete already made, like in a kit? Never seen something like that.
            Those cabinets are nice. Wish I had seen them before I did my kitchen. Would have saved a lot of time.
            I used similar facing. Turned out well
            My build progress
            My WFO Journal on Facebook
              GFRC nice but pricey.
                Yes they are pre fab by El Dorado stone Outdoor Veneer Building Blocks - Customize Your Outdoor Escape
                I found the price to be fine, the time and material you save is huge. They have a large variety of components and a nice online designer that makes it easy. they even calculate the amount of veneer you need.
                You just un pack place in position bolt together and cut out the holes for BBQ, drawers etc. I used a skill saw with a concrete blade, cut pretty smooth.
                  I did have help
                    My Forno Bravo Primavera 70 goes in the corner and is 42 inches wide so I am making a extension to my boxes to support the pizza oven. This will then be covered with outdoor plywood and a layer of 1/2 " hardy backer board.
                      Painted ready to be bolted to the cabinet
                        Stand bolted to cabinets
                          Wanted to raise the Pizza oven so blocks were added
                            I had some left over siding from the cabinet cut-outs so I glued and screwed those on the help with the finished stone work that will be done later.
                              Ready for the move
