I am in the process of building a barrel style oven, my base is already built and I already purchased the correct firebricks, 3" insulation board for the hearth and sides and 2" blanket for the dome. Originally the plan was to build a 36X42 oven with a 12X20 rectangle door opening offset about 4-6" and 16" dome height, since I have a little space to play with I would like to go 40" wide X 36" deep, what problems will this create if any? what other dimensions would I need to change to make this work?
Is it a problem to build sidewalls with the bricks on their side? there will be 3" ins. and blocks supporting the walls so I don't think there will be any support issues.
Thanks in advance for your help.
