Hello,
Newbie wanting to build a small wood fired oven; would appreciate any input from more experienced oven builders.
My idea is an oven with I.D. around 22", dome construction built on a 4" high first course w/total dome height 15" and door opening at recommended proportion.
My questions regard the oven construction; want oven to be as small/light as possible; to heat up as quickly as possible and stay hot enough to cook 4-6 small pizzas.
I also want to burn charcoal (natural hardwood) if possible as it is easier to obtain.
Am thinking of using split brick 1 1/4" thick laid flat then the insulating blanket and stucco finish for a 3-4" total wall thickness.
What should the base be built out of to reduce overall weight (want to keep oven and base in the 300-400lb area) and achieve enough insulating quality?
Also is firebrick easily cut by hand (hammer/brick set or diamond saw to score)?
Thank you for any information.
