Material between wall and cooking floor
  • Material between wall and cooking floor
    After laying the cooking bricks and placing the 3 section dome, there is space between the edges of the bricks and the dome wall. What should I fill the gaps in with to prevent the brick so from shifting? It is more noticeable at the entrance. Thanks!
    Re: Material between wall and cooking floor
    Ashes usually fill areas like that. It sounds like you may be assembling an oven from fornobravo...is that correct? If you have much of a crack to fill you might contact their customer service for a specific answer or post a picture. Ashes filled the gaps in the floor and around the edges in my pompeii oven.
    Lee B.
    DFW area, Texas, USA
      I'm planing to build my first barrel shaped brick oven , but i'm unsure of the floor . Can i just use a vermiculite and cement mixed base and reinforce it with some re-bar , or should i first throw a slab of plain concrete and the the vermiculite . What i'm trying to ask is , is the vermiculite and cement base strong enough to support the oven
        Vcrete in not strong enough alone to support an oven. I suggest you look at the free oven plans from Forno Bravo to help you. The support structure will be the same regardless of oven style.
          At least 4" of rebar-inforced concrete support slab. Then at least a 4" slab of vcrete. If you're building a barrel vault for retained-heat bread-making, the more under-floor insulation the better.
            No rebar in vcrete - it's too crumbly (if you do it right) for reinforcement. Vermicrete should only see well-distributed compressive loads. It'll support the oven, but you could punch a screwdriver right through it. It's unsuitable for a floor (again, too crumbly). It's an insulation layer below the brick cooking floor.
            Last edited by vtsteve; 09-16-2014, 10:53 AM. Reason: Added brick cooking floor note
