right hand side of thread appears to be missing
Re: right hand side of thread appears to be missing
That is because your pictures are too large. Resize them and, then edit your post. You can also use the thumbnail (paperclip) icon to add them full size
I think that 640 X 180 works pretty good. But, if you really want them to be viewed full sized, you can use the manage attachments explained hereOriginally posted by Tractor View PostAh ok thanks I'll try that but what size should they be?
Trac
Sometimes you can go to the thread, select 'edit', double click on the picture and then select a size from the screen that comes up. That might make it easy to make it smaller.
Another thing you can do is to hold the control key down and touch the '-' key. Sometimes that makes the screen fit better on your monitor.
HTH
Lee B.
DFW area, Texas, USA
