Sorry couple more questions as I've just got my P70 all set up.
1. Is there supposed to be a gap between the floor tiles and the edge of the dome? Mine has gaps all the way around the perimeter and just inside the oven opening the gaps are bigger. Is this normal? Cause for concern?
2. Likewise, right above this gap on the right side the interior part of the dome isn't perfectly flat. As far as I can tell it's not a crack but I'm not sure whether this is normal or a crack that was repaired. Should I be concerned? Is this normal? Is this going to cause issues when I cure it?
TIA.
TIA.
