I feel like I've read about a million posts in the FB forum -- thanks everyone for being so generous with your experiences. I've got a Pompeii kit sitting in my backyard, and the time is coming to put all that reading to work.
I have a professional welder friend who is going to build me a stand for the oven, so I can skip the concrete block process. Footings will be 10" pipe buried about 3' in the ground, to which the legs of the support stand will be attached.
Questions!
1) is there anyone who's gone this way (metal stand rather than cement blocks) who has an opinion on whether a concrete pad poured onto the top of the stand is necessary to support the oven, or whether I could build directly on the stand itself (starting with the insulating layer)
2) the floor tiles FB is now supplying are 2" thick. The primary purpose of the oven will be to bake bread. Should I consider adding 1 1/4" firebrick splits under the floor to increase the mass somewhat?
3) do I need to use firebrick for the floor of the vent landing? And what about an insulating space between the front of the oven floor and the beginning of the vent landing so that I'm not losing heat to where it's not needed (i.e. the vent landing floor?
Looking forward to learning from those with much more experience than I have!
Questions!
