Hi folks,
It?s been great to look through so many builds, glean so much useful information, and see the remarkable craftsmanship on display in this forum... but now that I am planning my own WFO build I finally have to stop lurking and ask a couple of newbie questions
I definitely want to build a round domed oven like most of those I?ve seen here, rather than a barrel, and it must achieve those high temps for great pizza, but I also want to be able to bake plenty of bread. Although I have figured out most of the details of the construction I am still not sure on two points of scale: namely the ideal internal diameter of the dome and the thickness of the dome.
I am tempted to make mine at 1200mm / approx. 47? internal, but I see that most builds are in the 32 to 42? range, and I guess there is good reason for this. Is 47? a bit mad? Do those of you with 42? ovens ever wish they were a little bigger, or are they plenty? Even drawing it out I couldn?t be sure ? I?d hate to make it at 42? and wish it was a little bigger afterwards. For pizza, I?m sure a smaller oven would be fine, perhaps better (?), but I am wondering about the bread side of things?
As for the dome, what thickness / thermal mass would folks recommend, particularly with bread in mind? I will certainly be insulating it thoroughly, but any views on the thickness of the brick dome and any further render before the insulation layer would be very helpful.
Finally, can anyone recommend a suitable bench saw (that is available in the UK) for the brickwork, that will not break the bank but still do a decent job on all those angled cuts?
Thanks in advance
JV
Thanks in advance
JV
