I wanted to make myself a pizza oven
I remember my mother had one that she build out of mud, brick and cement
She used to bake all the breads and things
Hers was a big oven in a shed
I only wanted a little oven, so I set out looking at building one
First problem was my deck is too small for a big oven so I had to build it off my deck 2mt high on a metal pole
The platform comes just over the edge of my deck
Of that I have build my wood storage box with openings at both ends so that I can put the wood in from the outside
next I but a 1'' fibro sheeting that is designed for fire places that are build inside on wooden floors
on top of that is a row of bricks with a refectory mortar mix as my hearth over the bricks then I have my fireclay and sand bedding on that I have clay bricks
On the out side I have used thermo blocks which are the size of besser blocks
I have tested these at my work on the glass melting furnace
My oven inside is clay bricks out side is thermo block
This is the stage that I am up to at the moment
Next I will line it with insulation foil and refractory mortar mix
Will put photos up very soon
