There has been a few discussions on using plain red clay bricks on this forum, and I personally was wondering about this. Well, here's the scoop.
As documented in another post, I built a temporary oven similar to the temp one seen on the brick oven pages. I used some patio blocks and some red clay bricks. the oven was used a few times for cooking, but in all honesty it was quite inconvenient due to it's height and size, so it ended up being a very good backyard brush disposal fireplace and marshmallow cooker. Last night I needed to move it due to a tree company coming over to drop a huge oak in my yard.
Here's the punch line: Both the red clay bricks and the concrete patio blocks (they sort of look like cinder blocks but just 1.5 inch thick) were extremely brittle and broke very easily. This is after about 10 firings.
The point I'm making here is that it's clear that if building a permanent oven, firebrick is essential and spending the amount of time it takes to make a proper oven shouldn't be wasted using any morter or brick material that's not intended to take the high heat a oven can produce. Hopefully I helped someone avoid a mistake.
maybe not
they use concrete blocks for the base and fill
