Re: Canada - Hard Time Getting Material?
Tony, Dmun, Versachi,
Here's the link to the parent company: ANH Refractories. I've contacted them for further info on Canadian locations.
Cheers,
Jim
Heh Super, I paid $2.50 for a full brick here in Thunder Bay so I feel your pain. I believe the brick was shipped to TBay from out west. If it's the same manufacturer that may explain the extra cost. Good luck to ya on your build.
John
Originally posted by SuperT View Posta 2" Mineral Wool Board for the Hearth Slab insulating layer.
we built an annealing oven that we use for stress relieving iron castings. It is
simply a box (2'x2'x3') made from sheets of rigid 2" 1900 degree
insulating board. A.P. Green is a large refractory supplier with offices
in many locations - here in Ottawa they have a product called Insblock
19. A box of 5 2"x12"x36" sheets costs about 100.00 CDN.
And by the way, Home Depot sucks everywhere. As the saying goes, when you pay peanuts, you get monkeys.
Yes; I assumed because it was a castable it was interchangeable with the vermiculite, which also is used on the hearth slab.
I ordered double the amount of Insulfrax and am going to double the normal amount on the outside of the dome, chicken wire it and outdoor stucco it as per the instructions.
Regardless, thanks for the tip...these guys are great to deal with and are sending me an e-mail with the safety info on the product.
Looks like my best deal on fire brick is going to be $2.78 for the full size. Going to get that finished up today.
Tony
Tony,
Matrilite is not meant to hold weight. It's a castable insulator only. I'm using it over the insulating batts on the dome, instead of vermiculite/Portland.
Jim
Home Depot in SSM stinks. I called for pricing on Refractory Mortar and Fire Bricks two hours ago and they have not called back yet with prices.
I followed CANUCKJIM's lead and talked to Elvis at Alphatherm this morning. Extremely helpful and recommended a 2" Mineral Wool Board for the Hearth Slab insulating layer. He said several contractors have been using it lately in professional restaurant applications (it had been backlogged in production for about a year) and what they like about it is its compression factor (ability to hold weight?) is pretty strong. Also he claims it is good up to 1900 degrees, easy to cut with a small saw or knife, about $115 per carton of 2" which will do about 48 sq ft (16 pieces at 3ft x 1ft) and safe to use for this application, as I specifically asked about potential contamination while cooking. Too me it sounds like an fire retardant acoustical tile type product.
Not knowing exactly which product it is, I am cautiously optimistic, but will report more as I find out on this potential new insulator. He didn't recommend the Matrilite only because it is somewhat porous and as with many castable insulators might potentially not hold the weight of the brick rings without sinking.
Tony
I'm on to the Home Depot tomorrow and will report back. This info is invaluable and much appreciated.
Tony
Originally posted by SuperT View PostThe largest size is a 4L pail (pre-mixed) for about $13 Canadian. The yield is about 15 bricks for 1L, which tells me the large container can do about 50 bricks.
The same store also quoted me $2.48 per brick 4.5 x 9 x 1 1/4"..does this sound about right?
Tony,
Where you live, I'd go with two inches of batt, plus two to three inches of Matrilite over that. Can't have too much insulation, especially in the Sault.
Jim
Sounds like a similar thing to Heat Stop Premix in a pail. Data sheet says interior use only.
I'd keep looking for something closer to Refmix.
Christo
Hey guys;
Just got back from my local Timbre-Mart. They carry a refractory Mortar product by a company called BoMix. The details are located at
bomix?
Again not trying to take business from FB, but being that the area I'm in is remote, can anyone tell me if this product will work? They have it in stock. The largest size is a 4L pail (pre-mixed) for about $13 Canadian. The yield is about 15 bricks for 1L, which tells me the large container can do about 50 bricks.
Also, for the 43" diameter Pompeii, can anyone tell me how many full bricks I would roughly need, inclusive of the floor? It's hard to make the calculation with the half brick consideration.
I am having some luck in the Toronto area with Insulfrax and Cal-Sil board type product, although the board is not cheap.
Really hoping the Matrilite product is the key...otherwise I will likely double/triple up on the Insulfrax blanket, chicken wire it and stucco.
Almost ready to go...
Tony
Tony,
If you strike out on the cross border connection, I've recently found a refractory supplier in Toronto, Alphatherm, that will have everything you need. Have a look at this thread for the details: http://www.fornobravo.com/forum/28/v...es-2126-2.html. It may be, too, that they could steer you a supplier closer to you.
Jim
That's excellent. I am going over there today. I will have a look around. Most things are now duty free, and its usually just the taxes, but there is an on-line duty list which I will check. Mainly I was concerned about shipping over there and going to pick it up.
Tony
Here's a fireplace store in Sault Ste Marie. Give 'em a call - they can point you in the right direction. I don't think you will have any customs problems with this stuff, it's not more hazardous than ordinary masonry products. You may have to pay import duty, but you would have to do that anyway.
Hello Gang
I've been on holidays so I haven't been working on the oven much, but with fall approaching I gotta get moving. Hearth slab is built and ready but I am having a heck of a time in Northern, ON Canada getting anything. I don't know any local masons and the local hardware stores look at me like I'm speaking in tongues. We do have a Home Depot but the seem to carry only Quick-Crete type products and when I got to the contractors desk, they are too busy to help. Here are some questions I have:
-I really want to use the Cal-Sil board, the Insulfrax and a Refractory mortar but can't find a similar products available in my region. I know I can order through FB store, but the shipping is outrageous. The only saving grace is that I live in a place called Sault Ste. Marie, ON which is on the border with Michigan (although it is a pretty small town on the US side) I usually get things shipped and go over and pick them up (5 minute drive).
My issue is that I imagine most of this stuff needs special handling/chemical clearance to get over an international border. Can anyone make any suggestions for Canadian Suppliers or alternatives for the three things I need?
TonyTags: None
