I've got my stand all layed out and ready to pour the concrete inside the blocks but I need to get the blocks to lay flat after installing the angle iron. What is the easiest way (other than a wet diamond blade) to cut out for the angle iron so the blocks will lay flat?
Re: Cutting concrete block
Originally posted by Dan94550 View PostI've got my stand all layed out and ready to pour the concrete inside the blocks but I need to get the blocks to lay flat after installing the angle iron. What is the easiest way (other than a wet diamond blade) to cut out for the angle iron so the blocks will lay flat?
Ken2 PhotosKen H. - Kentucky
42" Pompeii
Originally posted by maver View PostBut the easiest way is to set the angle iron outside the blocks and let your mortar make up the 3-5mm difference!
When you put the forms on the block stand for the hearth, make sure they are level (the blocks on the angle iron will stick up just a bit higher) and pour the hearth. No one will ever know. Shouldn't be any structural issues.
That's how I'd do it if I had to do it again.
KenKen H. - Kentucky
42" Pompeii
Thanks guys. I tried the skill saw yesterday and the old blade I had on there broke and I'm having a hell of a time trying to take off what is remaining on the shank. The blade I had on my angle grinder was for metal. I will go out and buy some new blades and continue.
Home Depot has started carrying good and cheap diamond blades for cutting brick, block and stone. They are a lot faster and easier than the old fashioned black masonry blades -- and not that much more expensive. They work really well at first when they are still sharp, so cutting block is a breeze.
Originally posted by james View Postso cutting block is a breeze..
No, really, get the diamond blade for the angle grinder. It's worth the money, and you'll use it a lot. And buy a good face mask while you're there. Big Dust Alert.
I always use a Skill saw and a full size blade. I am part of the "buy a cheap one and kill it" clan.
Make sure you get a metal blade for the angle iron, not a masonry blade! You can power your way through angle iron with the wrong blade, but it ruins the blade and is a big mess.
Originally posted by Dan94550 View PostUnfortunately I am going the dry fit route so there isn't any mortar gap to make up the difference.
