when is a brick a brick or a fire brick ???
  • #16
    Re: when is a brick a brick or a fire brick ???
    more question than reply: I have bricks from the chimney of a 1950 oil burning heater. Can I build an oven out of them? They are solid, large, dense and dark red. I would appreciate anyone's help, Thanks, Jon.
    • #17
      Hi, I’m also new here so be gentle. Iv built my brick oven a 900mm with a fire brick base and solid brick dome. I’m ready to place the flue and now the finish. It’s a single skin
      of brick tightly joint and I’m seeking advice on the outer finish. Do I just cement render it or does it need some added insulation. My late father a stone mason just built these in his day in single skin of bricks and they worked a treat! Any advice welcome. John
      • #18
        Hi John,
        Welcome to the forum. Yes, the dome needs insulation. I hope that the under floor and dome has insulation also.
        JTB1 Jon,
        Sorry for the no reply.
        Joe Watson, "A year from now, you will have wished that you had started today"
        My Web Album
