I have been advised to form my dome as a parabolic? hyperbolic? 3D shape.
I plan to use styrofoam or solid insulation sheets and interlock them as several have done; placing the 1/2 firebricks as concentric reducing circumference courses.
I will try to pack construction sand between the vanes although others have had satisfactory results omitting this step, but to quote (or misquote?) a famous bulider, overdo it or don't do it
My question is two-fold:
1- I have seen images of the vanes but not on how the template was made to scribe that profile. Can you specify the URL where that procedure is started? ___
2- If you know of no relevant photo images on-line, can you describe how I should draw the correct parabolic? curve for a 42 inch diameter oven? ___
Thanks,
Marcel
marceld@efn.org
Thanks,
Marcel
marceld@efn.org
